Just a quick feature request, unless someone can explain how to do this with the current version.
I would like to place duplicated files on different storage controllers. I have 2 x HP Smart Array p410's with about the same amount of storage on each controller.
- from my perspective write performance for files going to different controllers should be faster than a file being duplicated onto the same controller. - if a controller fails I have a cope of all of the data and nothing stops working. - read performance could also be better as the file will be coming from two different paths, with two sets of controllers, cache involved.
The only way I can think of doing this is the create a pool of drives for each controller, then mirror them with either Windows or a third party tool or even create a nest drive pool out of the two other pools.
browned
