S.M.A.R.T support for RaidSonic ICY BOX IB-3664SU3
Hi all,
does anyone know if StableBit Scanner can get S.M.A.R.T data through the eSATA interface of the RaidSonic ICY BOX IB-3664SU3 external enclosure?
I haven't find out which controller card this unit has.
Thanks in advance
Per
That depends on the controller cards used in the host system.
If you have the eSATA controller already, you can check in the Device Manager (run "devmgmt.msc"), and check the "Storage Controllers".
Otherwise, if you need to purchase one, we recommend a Marvell or ASMedia based chipset (avoid Silicon Images).
