I am using Drivepool now for aprx. one Month, works fine. Now I found 2 Topics I want to ask:
I am using some 8TB Seagate Archive V2 as Archivepool with redundancy. As Cache, I first use 2 SSD´s each 480GB. All works fine but write speed is not as fast as writing to a single SSD. After a while, i had to copy files larger than the SSD Size do the pool and write speed drops to aprx. 35MB/s as expected. Larger SSD´s are expensive, so I tried to use 2 fast spinning Disks as Cache, marked them as "SSD" in the Balancer "SSD Optimizer" (all other Balancers are disabled). It works as expected, but again not as fast as writing to a single Disk.
The Files are Backup file, so I want to ask if there is a possibility to use only one Disk as "SSD Cache" and after finishing writing to this Disk the Balancer copies the file(s) to my duplicated Archive Disks. I know that for the first time of the copy all files are only on one Disk, if this Disk dies, all files are gone. However, as these files are backup files, no problem, I start Backup again.
The second question is about automation the Backup Process. Is it possible to get information about the Balancing (% Ready, .. ) with an external scripting language?
pap
Hi again
Thanks for Help
Best Regards from Austria
Peter
