For some unknown reason DP is not seeing the 4 HDDs in a HP Microserver (Gen8), just the boot SSD.
It was working fine under Win 2012 R2, but a separate s/w incompatibility has meant changing to Win10 Pro... Initially the drives were seen, however there was a constant duplication error notice - so, having used alt s/w to compare my data on the pool (which was fine) I uninstalled DP -> formatted 2 of the drives -> copied the data across to them -> formatted the other two -> & reinstalled DP.
Now SB Scanner can see all 5 drives - & I've tried both the 2.2.0.619_x64_BETA (as that's the version I had to hand) & 2.2.0.651_x64_BETA...
...so, any ideas?
Completely separately, for the last week or so I've been getting regular pop ups saying that I need to activate both DP & Scanner on both this & my main server - & whilst it accepts the license each time, it keeps on reoccurring... Is this a issue at your end?
PocketDemon
...so, any ideas?
7 answers to this question
