1) I recently removed and re-added a drive from my drive pool while juggling some file placement issues and it's left behind an old PoolPart.GUID directory that I can't seem to delete. There are no files and all the "leaf" directories (directories that don't have anything in them) report back as "access is denied" whenever I try to access/delete/change permissions.
I'm running with admin privilages as well. reboots haven't cleared up the broken folders either. CHKDSK is clean as well... this is on a w2k2012 r2 OS.
2) I've also noticed i have another old PoolPart.GUID directory on another drive. This time, it *does* contain files (~2.8GB's worth 1000's of files). Last touched more than a year ago.. This was probably from another drive removal and then re-add. The files are still readable and directories are accessible (unlike issue #1).
Anyone know of a way to easily validate the files in this old PoolPart are safe to delete? It's a lot of directories and a lot of files.
2 issues i was hoping to get some advice on:
thanks,
