I am rebuilding my headless server with a mix of new and recycled parts:
MSI B85M-E45 Mobo
G1850 CPU
12 GB RAM (2 x 4GB and 2 x 2GB) - 6GB of this is as a RAMDisk and used for time-shifting
2 x Samsung F4 2TB HDD
1 x WD Red 6TB HDD
64SSD - have both a Crucial M4 and Sandisk Ultra Plus. Cannot decided which one is best to us.
2 x DVB-T tuner cards
1 x DVB-S2 tuner card
It is going to be running Windows 10 as the OS.
It is going to be using Argus TV backend for recording TV and playing live TV. I will also install Emby server to stream DVDs and music.
It will also, of course, have Stablebit Drivepool and Scanner installed.
My advice, really, is how best to set up Windows and my PVR software to work best with Stablebit.
I will be pooling all three HDDs to give me 10TB space and then letting Stablebit balance recordings based on evenly spacing them over the drives and subject to load/heat.
What is the suggested time to tell Windows to spin down my hard drives?
I use to have this set at 5 mins but now I am beginning to think that perhaps this is a bad idea because my server is constantly going to be waking up each harddrive in turn to make each new recording and I know that start/stop is far worse for hard drives than having them on constantly.
What would you suggest as the best compromise?
I was thinking about either turning off spindown altogether - i.e. as long as the serve is in use, the hard drives are all spinning or setting spindown to a long duration (say 3 hours) so the chances are that any hard drive will be called upon before it has had to spin down.
Apologies if the above is quite complicated - any guidance would be much appreciated.
elsmandino
