Anyone else having a problem attaching a drive? I've tried this several times now with different cloud providers and the results are always the same. I can create a drive just fine, but as soon as I detach the drive then try and reattach it, it's like my network card goes dead.
I can't browse the Internet, applications that use the Internet do not work. I can't even access my router by IP. I tried to manually restart the CloudDrive service but it stalls and eventually gives me and error and gets stuck on "Stopping".
This has happened with Box.net and Amazon Cloud Drive. The only way to undo this is to restart my computer by hardresetting it. I can't even gracefully restart it because it gets stuck on "Restarting" because I believe the CloudDrive Shutdown Service is attempting to do something.
conjuror
