In a boneheaded move I dropped an external drive off the desk onto the floor.  A quick chkdsk turned up no issues, but I've gone into Scanner and Marked all Readable blocks Unchecked then initiated a check.
If that comes back clean, are there any other checks I could/should do to verify if the disk received any damage?
7 answers to this question
Oh no!
Well, I'm glad that it didn't break, right then and there! (i've done that a couple of times :( ).
If Scanner gives it a clean bill of health, then you may be fine.
However, I'd ... prepare for the worse. If it's in a pool, I'd use the "Disk Usage limiter" balancer to only allow duplicated data on the drive. At least for a couple of weeks, to make sure there wasn't any "growing" damage (such as a crack that gets bigger over time).
Ok.  Scanner is about 70% done.  It's the destination for local CrashPlan backups, and was replacing a 4TB drive I haven't wiped yet.  I'll leave the 4TB drive alone for a couple weeks in case this one dies.  If this one get a clean bill of health from the scan and lasts through a couple of weeks of CrashPlan backups I'll assume it's good and wipe the 4TB.
Technically, if the 5TB drive dies and I revert back to using the 4TB drive, I'll lose a few versions of files, but given the data that won't be a problem.
So far so good.  Scanner gave it a clean bill of health and CrashPlan has been backing two computers up to it for a couple days now.  In another week or two I'll consider it good and add the old one (4TB) to DrivePool.
Crashplan has continued to back up to the dropped drive for over a week now.  I re-marked all readable blocks as as unchecked and kicked off Scanner one more time.  It's about 55% done as of right now.  If that comes out clean, I'm going to assume this drive is good and re-purpose the drive it's replacing.
Fingers crossed! lol
