I have a fairly new server running WSE2012R2. I have DrivePool 2.x latest version installed. One pool configured (F:) and it is made up of 4-4TB and 1-6TB HGST NAS drives all on my mobo's Intel controller. Boot device is a 256G SSD also on Intel and there is one other 1TB drive dedicated to system backups on a secondary Marvell onboard chip controller. No other disks although I do have a slim DVD installed on a add-on controller (Siig) 2-port SATAIII card.
My system backups are configured to do daily backups of the C: (SSD) drive so I could recover with a bare metal recovery. In no way are any of the pool drives or the pool itself involved in nightly system backups. They do hold some of the relocated system folders (Client Backups mainly) but those are not backed up in the dailys. The backups are configured to run at 11:30pm and are set to be Microsoft's version of "incremental". However about every 2 weeks the backup routine actually does a full back up on the system partition and then does incrementals from that point on until it decides the next full backup is needed. Whenever that full backup happens, I always get several nondescript disk warning errors that I have traced back to the DrivePool drive. (F:). The errors (typically between 2-8 identical warnings) all occur at exactly the same time stamp in the Windows Logs right at the completion time of the backup. I assume it's basically finishing writing the ~24 gig backup files at that point and also creating the new volume for the backup set and/or clearing out old ones, which is what, I suspect, triggers the errors as the DrivePool service gets notified of a bunch of disk/volume changes.
Anyway the error is: Level: Warning Source: disk Event ID: 51 Task Category: None Message: An error was detected on device \Device\Harddisk8\DR19 during a paging operation.
Always 'Harddisk8' which maps to the DrivePool drive. The DR19 part does vary.
When I look at the DrivePool logs I see these types of messages (Windows Logs has the 8 warnings at exactly time stamp 06:37:34Z): DrivePool.Service.exe Information 0 [Disks] Updating disks / volumes... 2015-04-08 06:37:32Z 721806531075 DrivePool.Service.exe Information 0 [FsControl] Clear pool mode: PoolModeMissingDisk (key=PoolPartUpdate) 2015-04-08 06:37:34Z 721812554682 DrivePool.Service.exe Information 0 [FsControl] Set overall pool mode: PoolModeNormal 2015-04-08 06:37:34Z 721812556450 DrivePool.Service.exe Information 0 [FsControl] Clear pool mode: PoolModeReadOnly (key=PoolPartUpdate) 2015-04-08 06:37:34Z 721812557941 DrivePool.Service.exe Information 0 [FsControl] Set overall pool mode: PoolModeNormal 2015-04-08 06:37:34Z 721812558843 DrivePool.Service.exe Information 0 [FsControl] Clear pool mode: PoolModeNoMeasure (key=PoolPartUpdate) 2015-04-08 06:37:34Z 721812560300 DrivePool.Service.exe Information 0 [FsControl] Set overall pool mode: PoolModeNormal 2015-04-08 06:37:34Z 721812561161 DrivePool.Service.exe Information 0 [Disks] Got Volume_Depart (volume ID: a440ea48-264c-4018-a7f6-c8bad40ea5db, plex ID: 00000000-0000-0000-0000-000000000000, %: 0)... 2015-04-08 06:37:34Z 721812637894 DrivePool.Service.exe Information 0 [Disks] Got Disk_Depart (disk ID: 21bec784-9493-4ef2-91ca-d1cb1b4f8564)... 2015-04-08 06:37:34Z 721812660975 DrivePool.Service.exe Information 0 [Disks] Got Pack_Depart (pack ID: c5d4e5d9-a1e6-4348-b50b-8b9492eaaa1b)... 2015-04-08 06:37:34Z 721812663010 DrivePool.Service.exe Information 0 [Disks] Updating disks / volumes... 2015-04-08 06:37:35Z 721815932045 DrivePool.Service.exe Information 0 [FsControl] Clear pool mode: PoolModeMissingDisk (key=PoolPartUpdate) 2015-04-08 06:37:36Z 721817871986 DrivePool.Service.exe Information 0 [FsControl] Set overall pool mode: PoolModeNormal 2015-04-08 06:37:36Z 721817873395 DrivePool.Service.exe Information 0 [FsControl] Clear pool mode: PoolModeReadOnly (key=PoolPartUpdate) 2015-04-08 06:37:36Z 721817874499 DrivePool.Service.exe Information 0 [FsControl] Set overall pool mode: PoolModeNormal 2015-04-08 06:37:36Z 721817875371 DrivePool.Service.exe Information 0 [FsControl] Clear pool mode: PoolModeNoMeasure (key=PoolPartUpdate) 2015-04-08 06:37:36Z 721817897265 DrivePool.Service.exe Information 0 [FsControl] Set overall pool mode: PoolModeNormal 2015-04-08 06:37:36Z 721817900386
The Event ID 51 disk error appears to be some generic MS warning message which is impossible to diagnose. The question is, is it something I should be concerned about and/or is it normal? It's entirely repeatable at every full backup but it's been happening for a few months now with no obvious bad effects.
I can upload the entire DP log from 4/7/2015 if needed. It did a full backup last night.
Sanders
Level: Warning
Source: disk
Event ID: 51
Task Category: None
Thanks.
