Hello. I have a weird issue. I have DrivePool 2.1.1.561 running on Windows 8.1 - 42 drives in pool #1. I have multiple folders in the root of the DrivePool (mounted as A: drive) that are shared out on my network.
When I select my Movies folder from the DrivePool directly on the machine (selecting Drive A: in File Explorer) the contents are listed quickly.
When I select the "W:" drive which is the network share of the "Movies" folder, the contents are very slow to display - initially shows 0 files, then take 5-10 seconds to list the full contents.
When I select the "W: network drive from another machine on my local network which is the "Movies" share, the contents display quickly.
I have check the DrivePool drive "A" and it does have indexing on it. I also checked the "Movies" share for drive "W" and it also has the indexing checked.
vorpel
Any help would be appreciated.
Thanks.
Edited by vorpel1 answer to this question
