  • Announcements
    • Christopher (Drashna)
      Login issues   11/07/17
      Getting Help   11/07/17
RumbleFang
Duplication problems
Hi folks,
I'm running a single pool consisting of around 16 x 2TB drives, and with the data they hold - with pool duplication - the total size is 21TB. Every few days, a sizeable chunk (2-3 TB) of that data drops out of duplication and so Drivepool dutifully goes to work re-duplicating it. All is good again, but then it happens again in a few days. I try to keep up to date with the latest beta releases, but I just wondered if this is a known issue?
(Windows 10 Pro (1703), Active Plug-Ins : #1 SSD Optimizer & #2 Disk Space Equalizer (by % used))
Thanks,
Bob
Hi Christopher,
I was using 2.2.0.798 (64-bit) yesterday, when the latest lump of data went walkies. I've since upgraded to 2.2.0.833 (and rebooted). The re-deduplication is still catching up after the upgrade & reboot. I'm on Win10 Pro (64-bit / 1703).
Thanks,
Bob
Well, I know we had a problem with Windows 7, and something like this occurring, and that was fixed in the beta builds.
That said, if this continues to happen, see if you can isolate the cause of this, if possible.
Or at least, capture it when file system logging is enabled:
and try running this:
http://wiki.covecube.com/StableBit_Troubleshooter
Create an account
Register a new account
Sign in
Sign In Now
