  • Announcements
    • Christopher (Drashna)
      Login issues   11/07/17
      Getting Help   11/07/17
Tekka
Missing Chunk. Is there a way to "fix" ?
Hi all,
I m using Clouddrive for a while now, with Amazon Cloud Drive ...
I know it is not supported (even less now :) ), but my data is not that "important" so I didn't mind losing files every now and then, or having slow download...
Now since few days I have an issue and wanted to know if there is any change I can resolve it ?
2 Chunk are missing... I see the files in Amazon cloud drive, but am not able to download them... And Clouddrive complain they are not found... and disconnect the disk :(
Now again, I would not mind lossing the file(s) contain in those chunk... My problem is that I don't know which one they are and if there is any chance I can just at least ignore those chunk ?
Ideally remove the files contains in those Chunk, and just then ignore them.... Problem right now is that i cannot keep my drive up more than few minutes as it just disconnect, not finding them...
Is there a way to clean that up ??
Regards,
Stephane
Create an account
Register a new account
Sign in
Sign In Now
