  • Announcements
    • Christopher (Drashna)
      Login issues   11/07/17
      Getting Help   11/07/17
borez
Delaying Drivepool start-up (integration with CloudDrive)
Hi there,
First and foremost, congrats on the stable release of CloudDrive. A milestone indeed!
Gave CloudDrive a re-spin, and it's much better integrated with Drivepool. I'm successfully running 3x duplication (one offline, one to the cloud via Clouddrive).
However, I need to remeasure the pool upon every startup - Drivepool kicks in before CloudDrive is started. I've tried these solutions but to no avail. my virtual disk dependency is correctly set for both CD and DP.
http://community.covecube.com/index.php?/topic/1085-how-to-delay-drivepool-service-after-reboot/
My observation on start up sequence:
1) The drivepool gets recognized almost instantaneously upon startup, but without the added cloudrive.
2) CD starts, gets mounted - then the drivepool gets updated immediately with new capacity. But by then the pool is dirty and I need to re-measure it.
EDIT: I also keep getting a "Duplication inconsistent" error, although I believe it's more of my placement rules than anything else. Is there any way to restrict the clouddrive to store only files with 3x duplication enabled? my backup priority would be for 2x dups to be fully offline, and 3x dups to have both offline and online.
6 answers to this question
Try this:
http://wiki.covecube.com/StableBit_DrivePool_2.x_Advanced_Settings
Set "CoveFs_WaitForVolumesOnMountMs" 50000, and see if that helps.
Otherwise, you could run "services.msc", find the "StableBit DrivePool Service", right click on it and select "Properties". Then set the "startup type" to "Automatic (Delayed)", and that may help with the issue.
Try this:
Unfortunately no go. Tried both options including the Automatic (delayed) service. The service does get delayed. but it still re-measures. After that i get a duplication inconsistent message and need to re-check all over.
The other option is to add the StableBit CloudDrive service as a dependancy for StableBit DrivePool.  However, this is a bit more complicated, and requires registry editing.
Unfortunately tried this, and go go. This is a deal breaker, and I'll be removing the Clouddrive from the drivepool. I'm going back to manual backups - hope future iterations of DP can fix this integration.
Create an account
Register a new account
Sign in
Sign In Now
