So, after my controller card problems, I decided to load Stablebit Scanner 2.5.2.3103 Beta. I started a scan of all the drives and was monitoring it in the Dashboard. After a while, the Dashboard froze. I found on your wiki about a Dashboard freeze and ran the commands to create the Dump. The Dashboard became unfrozen and then closed. When I started it again, I received an error box stating that Drivepool had caused a problem with the Add-Ins and if I wanted to disable it. I just clicked on it and then Continue and it came back up. So, that was a little troubling, as I want Drivepool running more than Scanner. This happens whenever I open the Dashboard now.
After all that happened, I kept Dashboard open and when I would click on the Scanner tab, I noticed the memory usage of the Dashboard (in task manager) start to go up consistently, when I switched to one of the other tabs, the memory would go down or stay stable. I'll see what happens when it's done with the disk scans.
Any reason you can think of for the memory increase?
I can upload the dump file if you would like. Do you have a link for the upload? The one on the wiki seems to be for version 1 or 2 of Drivepool.
One more thing I noticed as it's scanning the drives. I have one drive that's "Waiting to scan (temperature equalization)". What does this mean?
dreamland95
Hi Christopher,
Thanks again,
Dave
