So I unfortunately had a drive throw SMART errors and eventually gave up it's ghost. While it was giving errors and I had a replacement on order, I did the following:
1) I setup new placement rules that moved some more "important" data off the drive and moved some more non-essential stuff only to that drive
2) My pool was pretty full (drives were well past their 95% limit) so rebalancing would complain of not being able to move X amounts of GBs
3) eventually the drive got worse (more and moreunreadable sectors) at which point I tried to remove the drive from the drive pool (but only checking off skipping duplication for faster drive removal)
4) in that process, the drive *really* died and is now not even mountable in windows. sometimes it'll spin up but the the drive name defaulted to "local disk" in windows and it complains that the drive is not readable. During this time, the drive showed up in drivepool with the generic label and I clicked "Remove" and it disappeared. It didn't even have a prompt on how to remove like before. Poof, it vanished.
Okay, so the drive is dead and it took along with it a few TB of data. I can live with that since I managed to pull a list of files and nothing critical was amongst it.
Now, the drive pool is giving a Duplication Warnings saying ~15 files are missing:
10:26:38.1: Warning: 0 : [FileDuplication] Error checking file \\?\GLOBALROOT\Device\HarddiskVolume15\[REDACTED] for duplication consistency. The system cannot find the path specified
10:26:40.3: Warning: 0 : [FileDuplication] Error checking file \\?\GLOBALROOT\Device\HarddiskVolume15\[REDACTED] for duplication consistency. The system cannot find the path specified
10:26:40.4: Warning: 0 : [FileDuplication] Error checking file \\?\GLOBALROOT\Device\HarddiskVolume15\[REDACTED] for duplication consistency. The system cannot find the path specified
10:27:03.6: Information: 0 : [FsControl] Set overall pool mode: PoolModeNoReportIncomplete (lastKey=FileDuplication, pool=4538dc0f-4f53-419c-a2bf-63406948c107)
I've tried clicking "Duplicate now" but after it re-measures, I get the exact same error message. Afraid to click Rebalancing...
What's also curious is when I spin up the drive and it mounts as "local disk", it DOES actually show up in Stablebit Scanner under the custom drive name I gave it and I can see there's a lot of activity (80-100+ MB/s at some points). What's going on here? Is the drive self scanning itself? SMART is showing a slew of realloc sectors (25k+) and the unreadable sector is 100+ now, vs 24-32 before... Should I leave the drive plugged in and let whatever is scanning it finish?
From what I've read in earlier posts, I've enabled file system logging in troubleshooting but not sure where that log is.
mr_yellow
Hi!
10:26:38.1: Warning: 0 : [FileDuplication] Error checking file \\?\GLOBALROOT\Device\HarddiskVolume15\[REDACTED] for duplication consistency. The system cannot find the path specified 10:26:40.3: Warning: 0 : [FileDuplication] Error checking file \\?\GLOBALROOT\Device\HarddiskVolume15\[REDACTED] for duplication consistency. The system cannot find the path specified 10:26:40.4: Warning: 0 : [FileDuplication] Error checking file \\?\GLOBALROOT\Device\HarddiskVolume15\[REDACTED] for duplication consistency. The system cannot find the path specified ... 10:27:03.6: Information: 0 : [FsControl] Set overall pool mode: PoolModeNoReportIncomplete (lastKey=FileDuplication, pool=4538dc0f-4f53-419c-a2bf-63406948c107)
Any advice?
