pjakesson Posted December 4, 2019 Posted December 4, 2019 Hello, After replacing a faulty disk I had to re-balance my pool. But it seems to be stuck at 99.9% Should I worry? Can I fix it? Thanks in advance Per Quote
0 OrozarBE Posted December 8, 2019 Posted December 8, 2019 I had that problem once. In my case it fixed itself after stopping the process and make a change in the plugins section. I made a change, saved, made the change undone, saved, restarted pc (probably unnecessary) and started balancing again. Quote
pjakesson
Hello,
Should I worry?
Can I fix it?
Thanks in advance
Per
