FQs19
  • Content Count
Everything posted by FQs19
  1. Thanks. I did that and just received an answer which solved my problem. It wasn't clear to me that I had to disable duplication instead of Change duplication from 2 copies to 1. I thought either way should work, but that isn't the case. I had to click on the folder I wanted to change duplication on, then click Change Duplication, then click on Disable. File Protection is still shown as Pool Duplication, which is a bit confusing since I'm now using Folder Duplication, but either way I have my duplication levels set the way I need them.
  2. I'm using Drivepool's latest version, 2.2.4.1162, on a Windows 10 Pro Version 2004 x64 pc. For whatever reason I can't change the File Protection from Pool File Duplication to Folder Duplication. I also can't even change the duplication level from 2 to 1 or even 2 to 3. I've uninstalled and reinstalled with no change in behavior. Drivepool still functions correctly. It shows up as a drive on my system. I can copy stuff into it and read stuff off of it. When I try to change the file protection, by clicking on Change Duplication, it asks to either Disable, Change, or Cancel.
