FQs19
FQs19's Achievements
  1. I've been having issues with Stablebit Scanner waking my pc up. I've tried looking in Event Viewer to see what's causing it, but there are over 1300 Kernel-Power events for each day. I know that Stablebit Scanner is not following the Settings I have configured because I have it set to only perform work between 2AM and 3:30AM and yet my PC is waking from Stablebit Scanner all day long. I do have Wake Up to Scan checked, but if I didn't, it won't wake up. Can someone please help me figure this out. Attached are my current settings and one ScannerService.log because the rest are too big to upload. I'm on Windows 10 Version 20H2 OS Build 19042.985 Scanner.Service-2021-06-03.log
  2. Thanks. I did that and just received an answer which solved my problem. It wasn't clear to me that I had to disable duplication instead of Change duplication from 2 copies to 1. I thought either way should work, but that isn't the case. I had to click on the folder I wanted to change duplication on, then click Change Duplication, then click on Disable. File Protection is still shown as Pool Duplication, which is a bit confusing since I'm now using Folder Duplication, but either way I have my duplication levels set the way I need them.
  3. I'm using Drivepool's latest version, 2.2.4.1162, on a Windows 10 Pro Version 2004 x64 pc. For whatever reason I can't change the File Protection from Pool File Duplication to Folder Duplication. I also can't even change the duplication level from 2 to 1 or even 2 to 3. I've uninstalled and reinstalled with no change in behavior. Drivepool still functions correctly. It shows up as a drive on my system. I can copy stuff into it and read stuff off of it. When I try to change the file protection, by clicking on Change Duplication, it asks to either Disable, Change, or Cancel. When I click on Change, it then asks How Many Copies? with 2 being highlighted (since that is my duplication level). I can not change this number and have it stick. I can enter any number I want, but it will immediately ask the same question again, How Many Copies? with 2 being highlighted. That is why I tried to reinstall Drivepool. I've also done an SFC scan and a chkdsk on all hard drives in my system. I found no errors. Can someone please help me? Thanks
