  • Announcements
    • Christopher (Drashna)
      Login issues   11/07/17
      Getting Help   11/07/17
pofo14
Default Amazon Drive Directory - Drive Pool
Hello,
I am experiencing an error in The Amazon Drive desktop application when i try to set the default sync folder on my PC as a folder on a pooled Drive in drivepool.
I have a basic drivepool setup and basically just have one JBOD Drive. When I set the Drive in the Amazon desktop tool, it never loads up and eventually say “this Drive is not supported”.
I was wondering if anyone else experienced this issue, and if there is something I need to tweak in my drivepool setting.
Thanks,
Ken
Create an account
Register a new account
Sign in
Sign In Now
