This afternoon I decided to remove a small (500GB) drive from my main storage pool so I could use it for something else. I selected the options to force close files and to duplicate later, but not to force remove because afaik there wasn't anything wrong with the drive (Scanner says it's fine; "oldest scanned block" was on May 4th) . Everything seemed fine, but I walked away for a few minutes and when I came back the Server Essentials Dashboard had mysteriously closed. I re-opened the dashboard, and when I clicked over to the DRIVEPOOL tab, it showed the "Removing drive... (93.9%)". It's been at 93.9% for at least the past three hours - something is clearly wrong. What should I do now? I had something similar happen last time I removed a drive to replace it with a larger one - that time I tried to just reboot the server, and that created a big mess so I would prefer not to go down that road again. What can I do? Any tips? When I hover over the drive, it currently shows all free space except for 2.79GB "other", so I think it's basically done removing the drive but it's somehow stuck.
I'm running version 2.2.2.934 on Win12r2 Essentials.
MattScott
TIA for any help you can provide.
0 answers to this question
