.anon Posted December 16, 2019 Posted December 16, 2019 Hello, The scanner is not working properly for me. - The drives were last checked over 25 days ago - When I click on "Start Check", nothing happens? - It is set to scan the system every evening from 2AM till 6AM. (the PC is on 24/7) Any ideas? Quote
0 HTWingNut Posted January 5, 2020 Posted January 5, 2020 I think it might be tied to number of days before next check. Although if you have it set to manually scan, it should scan regardless of what that setting is. I noticed this too. I only just recently purchased DrivePool and Scanner. But I decided to just have it start another scan, but it does nothing. I'll toy with the settings a bit and see. Hopefully the dev will chime in though, but your post is nearly 3 weeks old, so I dunno. Quote
.anon
Hello,
Any ideas?
