iceman1337 Posted April 23, 2023 Posted April 23, 2023 On 2.6.3.3969 Manual checks pass Run `chkdsk` with no errors. Run `Repair-Volumes` with no errors Enable Verbose logging for `chkdsk` Attempt to run the check. There is no helpful information on the scanner logs. Scanner.Service.exe Information 0 [Ipc] Starting task '8b2d504d-1c61-4429-9b1f-14467f2e32a9'... 2023-04-23 14:20:18Z 16555746052 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17100451435 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17100890108 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17101447960 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17102450610 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17102885800 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17103335446 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17103783329 Scanner.Service.exe Warning 0 [SmartDiskInfo] WMI SMART Not Supported. 2023-04-23 14:21:13Z 17104698157 I have attempted multiple reboots and cannot get StableBit Scanner to update the drive state. Quote
0 iceman1337 Posted April 23, 2023 Author Posted April 23, 2023 I have no idea the exact situation which "fixed" the issue, but here is what happened to eventually make the drive show up as healthy. Boot System Start StableBit Scanner Get Error for "File System Damaged" Attempt to Repair Volume From cmd run `chkdsk <drive> /f` --> Asks to confirm that all handles will be lost (note no errors foind) From powershell run `Repair-Volume -DriverLetter <drive> -Scan` (no errors reported) Reboot Quote
iceman1337
On 2.6.3.3969
Manual checks pass
