I have a pool (call it IANSPOOL) which has the following file system structure within it ....
IANSPOOL
--->Music
--->ITunes
----ITunes Music
I now create a symlink at IANSPOOL\Music\Music which points to IANSPOOL\Music\ITunes\ITunes Music
I used "mklink /d " to create the symlink
I checked that this worked, and sure enough I can display IANSPOOL\Music\Music in File Explorer and see all of the files under IANSPOOL\Music\ITunes\ITunes Music. IANSPOOL is shared on my network as \\ROOTMACHINE\IANSPOOL, and I checked that the symlink worked through the network. No problem.
Later that day I noticed that one of my applications that makes my music library available as a media stream only had a fraction of the library available, sure enough there was still a directory showing at IANSPOOL\Music\Music but it only contained a fraction of the actual files, and more importantly, it was no longer a symlink!!
Does anyone have a clue what could be going on?
Edit -- If it helps I've checked all the machines in my network and all have "fsutil behavior query symlinkevaluation" showing all modes set to enabled (L2L, L2R, R2L, and R2R)
TomTiddler
IANSPOOL
--->Music
--->ITunes
----ITunes Music
Edited by TomTiddlerClarification
0 answers to this question
