1 Drive in Pool showing strange info
Thunder7ga
As you can see in the attached image, Data2-DAS1 (Q:) is showing some strange info, like it isnt part of the pool, but yet it is?   I wasn't getting any errors until I checked the scrub status of SnapRaid, and it was having fatal errors trying to access the PoolPart ID info.....
Any ideas on what is going on, or what I should do to ensure the pool is working properly?
I believe I figured it out....seems Scanner marked a single block as bad, and since I had the option for DrivePool to allow Scanner to evacuate on any issue, it did so.   I'm going to add a 3rd drive to the pool, but for now I have disabled the scanner option to evacuate, the drive is healthy except for that 1 block, but will be ready for when it craps out entirely (and I have backups).
