Hi all: Newbie question. When you setup Snapraid config for backup and you use the entire drive letter e.g. E:/ for data instead of E:/Poolpart.GUID, what happens?
I assume that since the Poolpart folders are hidden, they are excluded from backup (default #hidden)?
I then assume you need to designate a Poolpart folder as non-hidden and non-system via a command line such as:
"attrib -H -S E:\PoolPart.GUID", but is this syntax correct as I want all the folders within Poolpart to be converted to non-system, non-hidden?
Basically, I have video files in separate folders within the poolpart folders, but outside of these I have data that I want to back up on the drives so I want all the drive content not just the poolpart folders. So trying to get it all in the snapraid backup and configure it correctly.
Bugman
Thanks in advance.
0 answers to this question
