I did some research and since 2013 Drivepool should support NFS shares, I also checked that the necessary setting in the config File is set to true (by default). Still I can't share folder via NFS, it gives me an error that brings me to the following link after googling it:
So basically it says you can't create NFS shares on a non physical disk. How come I read that Drivepool supports NFS then if Microsoft doesn't allow it?
EDIT: Partially solved! The Share name must NOT include whitespaces ! Since it automatically takes the Folder name you have to replace any whitespace with something else. Going to test now and see if it is finally possible to access my server throug xbmc, because smb sure is not working.
falc410
http://social.technet.microsoft.com/Forums/windowsserver/en-US/687aa6fe-0886-4f82-bc47-270b4692630b/i-cant-create-a-nfs-share-on-a-windows-2012-storage-serve-2012?forum=winserverfiles
