Bazzu85 Posted May 7, 2020 Share Posted May 7, 2020 Hi, here's my situation: as you see the drive fill plugin recognized that some file as to move from V to P (wrong basing the file rules) here's the file rules for the main folder with problems: As rule I'm expecting the files from V as to be placed in U (with more file spaces) what I'm missing? Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted May 9, 2020 Share Posted May 9, 2020 Try setting the balancing ratio (in the main tab) to 100% and see if that helps. Quote Link to comment Share on other sites More sharing options...
0 Bazzu85 Posted May 9, 2020 Author Share Posted May 9, 2020 11 hours ago, Christopher (Drashna) said: Try setting the balancing ratio (in the main tab) to 100% and see if that helps. Sorry, what you mean with main tab? Can you give me an example screenshot please? edit: I have done what you say but the problem remains.. with 95% previously I manually start the balancing but at the end remains as was.. with 100% the balance start emmediatly but as 95% remains as was.. The program insist to suggest every time to put the files in P: hard drive.. edit2: Now the data to be moved is less than initial because yesterday I added drive P to the balancing for the folder..after what I removed it and the file was moved to U: Today I have added some files and drivepool suggest everytime to put this in P: edit3: additional info: what is causing this behavior is the overfill balancer.. Quote Link to comment Share on other sites More sharing options...
0 Bazzu85 Posted May 12, 2020 Author Share Posted May 12, 2020 uppp.. can someone give me some help/suggestions?? now adding some files in Serie TV folder, the file are placed in U: HDD (correctly) but I have always this 1.11GB pending.. Quote Link to comment Share on other sites More sharing options...
Bazzu85
what I'm missing?
