I have two 10TB hard drives in my work computer. I want to use them as my important work data storage. I have some problems with the use. Although I use it with my own understanding, I want to ask someone to help Make sure everything I set is correct.
I need:
1. I don't want to use any automatic balancing to ensure that in any case I can unmount a separate hard drive to view continuous data.
2. Cooperate with StableBit Scanner. When an error occurs on one hard disk, the data can be automatically transferred to another hard disk.
This is my setup screen. Is there anything I did wrong?
3. If I reinstall the system, will the rebuild pool be exactly the same as my settings before the installation? I haven't tried it, does anyone have experience?
Is it possible to add Chinese language in future versions? (● '◡' ●)
zlskpotti
I need:
