I have one drive pool that is set for 2x file duplication. I noticed that when I went to folder duplication, I could exclude specific folders from duplication, so I did so with .System Volume Information and $RECYCLE.BIN. Now I'm wondering if I should have done that for .System Volume Information. What is the best state for both of these? I thought that the size SVI can grow too would just be a pool space waster...
I'm using the v2 release version of DrivePool and have noticed several different UI issues. One time, after removing a 3T drive (not forced) and replacing it with a 4T (in a pool with 1 other 3T and 4 other 4T's) that the pie chart showing divisions of assets (!) was fully closed but also showed 5.99T free in text above it after the new drive was inserted. I tried several things including a reboot and nothing corrected it. Then I removed the second 3T drive to replace it with a 4T (so now there are 6 4T's) and right after I put the new 4T in, the page redrew and the pie chart was corrected.
However, the chart showed about 900G unduplicated and did NOT start a duplicating pass. (I have the duplicate option set to immediate). After an hour it still hadn't done anything, so I selected the Remeasure option. At that point duplicating started right up.
A quirk or a bug? I'll switch over to the recent beta's of DP and Scanner and see if anything changes.
Also several occasions where the UI for Scanner went south (saying Not Responding). I had to kill the Scanner process, but then everything came back operational.
bblue
--Bill
