Running windows 10 with 4 x 4TB HD running of SATA from the motherboard. Been using this set up for several years with no problems. All windows 10 updates up to date. Although I am running 4 x 4TB in full duplication my drivepool is reporting 14 TB in windows file explorer PC. Windows system Admin show all 4 main drives healthy and shows the drive pool healthy. The drive pool seems to be working fine in that I can read and write files ok. However, my main issue is that I cannot access the background service. I am accessing locally and am running Sophos antivirus. I also cannot access the Stablebit Scanner background service either. Have rebooted several times.
Not sure if it is a problem but I am storing my onedrive folder on the drive pool.
I checked the error logs (C:\ProgramData\StableBit DrivePool\Service\ErrorReports) but there are no error logs since 2016 so no major errors.
Any ideas how I can get into the drivepool background service?
GeorgeS
Stablebit Drive Pool version: 2.1.1.561
Stablebit Scanner version: 2.5.1.3062
