Hi there. Usually, when i scan the pool for the duplication's coherence, if the program founds some file with multiple versions available, the duplication stops and a yellow triangle with an exclamation point inside appears: then i need to manually flag the option which allow to keep only the newest file and remove the oldest one. The question is: is it possible to make this option on by default? Thank you!
gabemorgath
