ilikemonkeys Posted September 27, 2018 Share Posted September 27, 2018 Tried to resize, but clusters are too small to accommodate the new size. I need to format the local drive with a larger cluster size. Will this delete all of my data? Thanks! Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted October 1, 2018 Share Posted October 1, 2018 Yes. You should be be able to expand the disk past that, though. And then you could add partitions to the disk, so you can get more available space. At this point, you may want to use StableBit DrivePool to pool the partitions together. And I think you've opened a ticket for this, as well. Quote Link to comment Share on other sites More sharing options...
ilikemonkeys
