Doing hierarchical pooing. 1 Master Pool with 3 child pools. 1 child pool holds 99% of all data and ALL internal disks. Other 2 pools are external hard drives and a cloud drive. The Cloud Drive is unstable and keeps going offline sending the entire master pool into read--only. Finally had to remove the Cloud Drive which is not desired.
Any way to indicate in the master pool to not go into read-only for a missing disk (child pool)?
The 1 child pool housing 99% of the data (and disks) will function normally.
Hughesco
~Thanks
