Hi
I have a minio s3 server running on truenas scale on my home lab.
The minio server is running only on http , as this is to use only on local network behind a firewall.
For test purposes i installed stablebit cloudrive on server 2025.
I can connect to my minio s3 server ok , but when i try to create a drive i get error "When DisablePayloadSigning is true, the request must be sent over HTTPS"
How can I bypass this error?
Thank you
PS: I tried edit advanced settings and put DisablePayloadSigning = false. This did not work. What are the accepted values for these fields?
Hmm. Some digging around suggests you might need to add it as
"DisablePayloadSigning": false
to your particular provider's section in the "%programdata%\StableBit CloudDrive\ProviderSettings.json" file?
(put a comma after the word "false" if it is not the last entry in the section)
