I’ll try to keep it concise. I have two 12 TB NAS HDDs in an Orico 2-bay JBOD enclosure, used as a backup target for StableBit DrivePool. Backup was mostly automatic, and I only checked it occasionally (roughly once a month).
Today I discovered that the two drives are not readable. MiniTool Partition Wizard reports the filesystem as OTHER.
Here’s what I’ve tried so far:
TestDisk 7.3-WIP – I attempted to recover the MBR/boot sector.
Before running TestDisk:
Backup boot sector: Status OK Sectors arenot identical
After using TestDisk to copy the backup boot sector over the main boot sector:
I also changed the partition type to NTFS using TestDisk. MiniTool Partition Wizard now shows the partition type as NTFS.
Current behavior:
Windows File Explorer assigns a drive letter, but the partition size is not recognized.
I cannot browse or access any files.
Quick scans in MiniTool Partition Wizard complete successfully with no errors.
Other details:
I have removed the drive from the Orico enclosure and am now using a different 1-bay enclosure. I initially thought the Orico enclosure might be the problem, but it isn’t. All files and the entire folder structure are visible via recovery software such as EaseUS Data Recovery Wizard.
The drives were previously part of a StableBit DrivePool backup setup, so the data may be stored in PoolPart folder structures.
The disks are visible in Disk Management, but still appear as unrecognized / RAW.
When I try to quickscan using testdisk_win.exe it's stuck at 99% with looks like an extra cylinder count:
I’m wondering if anyone has experience with restoring access to DrivePool backup disks that appear as NTFS but are unreadable, or suggestions on what I could try next to regain access to the files without losing data.
Thanks in advance for any advice!
TestDisk LOG:
Tue Nov 4 11:56:36 2025 Command line: TestDisk TestDisk 7.3-WIP, Data Recovery Utility, September 2025 Christophe GRENIER <grenier@cgsecurity.org> https://www.cgsecurity.org OS: Windows 8 (9200) Compiler: GCC 12.4, Cygwin32 3003.3 ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=512110190592 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=12000138624512 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=511553044480 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=512108789760 disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=12000136527872 Hard disk list Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - NVMe CL1-3D512-Q11 NVMe SSSTC 512GB, S/N:38F6_0156_30E8_16C0., FW:22321116 Disk \\.\PhysicalDrive1 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - NVMe BM9C1 Samsung 512GB, S/N:0025_3879_41B0_EF6D., FW:67430709 Disk \\.\PhysicalDrive2 - 12 TB / 10 TiB - CHS 1458933 255 63, sector size=512 - Seagate Expansion HDD, S/N:0000000000002HC0, FW:0003 Partition table type (auto): EFI GPT Disk \\.\PhysicalDrive2 - 12 TB / 10 TiB - Seagate Expansion HDD Partition table type: EFI GPT Interface Advanced hdr_size=92 hdr_lba_self=1 hdr_lba_alt=23437770751 (expected 23437770750) hdr_lba_start=34 hdr_lba_end=23437770718 hdr_lba_table=2 hdr_entries=128 hdr_entsz=128 check_part_gpt failed for partition 1 P MS Data 2048 23437768703 23437766656 [Basic data partition] 1 P MS Data 2048 23437768703 23437766656 [Basic data partition] gpt_change_part_type Change partition type: 1 P MS Data 2048 23437768703 23437766656 [Basic data partition] Change partition type: 1 P NTFS 2048 23437768703 23437766656 [Basic data partition] ntfs_boot_sector 1 P MS Data 2048 23437768703 23437766656 [Basic data partition] NTFS at 0/32/33 Info: size boot_sector 1962930145, partition 1962930176 filesystem size 4196945173078214977 23437766625 sectors_per_cluster 133 32 mft_lcn 160618196281190402 5780 mftmirr_lcn 13359365344649591654 1 clusters_per_mft_record 0 -10 clusters_per_index_record 102 -12 Boot sector Status: Bad Backup boot sector Status: OK Sectors are not identical. A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable. copy backup boot sector over boot sector ntfs_boot_sector 1 P MS Data 2048 23437768703 23437766656 [Basic data partition] NTFS at 0/32/33 Info: size boot_sector 1962930145, partition 1962930176 NTFS at 0/32/33 Info: size boot_sector 1962930145, partition 1962930176 filesystem size 23437766625 sectors_per_cluster 32 mft_lcn 5780 mftmirr_lcn 1 clusters_per_mft_record -10 clusters_per_index_record -12 Boot sector Status: OK Backup boot sector Status: OK Sectors are identical. A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable.
Interstellar
Hi all,
Current behavior:
Other details:
TestDisk LOG:
