lsymfr Posted October 4, 2016 Share Posted October 4, 2016 like it said in the question, since CloudDrive doesnt support Amazon Drive , when using the AWS key to connect amazon to Cloud Drive, what cloud storage is it using? Is it my amazon drive storage or ?? Quote Link to comment Share on other sites More sharing options...
0 Lawdie Posted October 5, 2016 Share Posted October 5, 2016 AWS is completely separate to Amazon Drive, on AWS you get charged per each file you write to the service and get a monthly bill. http://community.covecube.com/index.php?/topic/1588-amazon-cloud-drive-why-is-it-not-supported/?p=15083 Explains what version you need if you plan on using amazon Drive Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted October 8, 2016 Share Posted October 8, 2016 like it said in the question, since CloudDrive doesnt support Amazon Drive , when using the AWS key to connect amazon to Cloud Drive, what cloud storage is it using? Is it my amazon drive storage or ?? They're different services and we support Amazon S3 natively. We do support Amazon Cloud Drive, sort of. It's complicated. As Lawdie has linked. Basically, we do support it, but we do not recommend using it, right now. AWS is completely separate to Amazon Drive, on AWS you get charged per each file you write to the service and get a monthly bill. http://community.covecube.com/index.php?/topic/1588-amazon-cloud-drive-why-is-it-not-supported/?p=15083 Explains what version you need if you plan on using amazon Drive It's worse than that. Amazon charges you for the amount of data stored on their servers, as well as API calls, and for bandwidth usage. I've actually broken it down here: http://community.covecube.com/index.php?/topic/1268-cloud-providers/&do=findComment&comment=8445 But basically, "expensive". Quote Link to comment Share on other sites More sharing options...
lsymfr
