I was wondering, if Drive Pool and Cloud Drive in conjunction would support the following scenario:
If I install both on a notebook with an attached home based 8 TB USB Drive and the USB drive is being duplicated to a Cloud Drive of the same size and I later detach the notebook from the USB drive and go traveling, would ....
- the drive Pool still offer me access to all the files of the USB drive via the Cloud Drive without constantly reporting errors that the USB drive is missing?
- will it save new files to the Drive Pool while I am on the road and later add the missing file to the USB drive automatically once I am back home and the USB drive is attached again?
- delete files from the USB drive once its attached again, if I deleted them from the cloud drive while on the road?
Anything else I would need to be careful about in such a scenario? Like possible drive/data corruption etc?
Also ... if the USB drive was a network drive in the above scenario, would that also work or does it only work with local drives?
worldtravelgeek
Hi !
Thanks for answering
Alex
