TeleFragger
starting over?
Ok so I had a pool giving the false drive missing.. anyway I messed around so much it is a total mess.
I had a pool letter H. I removed 2 drives and formatted them and made a pool letter I
anyway.. I have all my files backed up on another computer but also a backup on I.
What I need to know is..
how do I get rid of H as I am having errors removing a drive in the pool. It is telling me access denied.
would it be easier for me to uninstall stablebit and format all drives then create a new pool? Oh also upgrade stablebit as I am still on the 2.1 with issues.
looking for direction.
Resetting the settings should really fix this issue.
Old pool information is stored in the settings store, and is what triggers this.
However, upgrading to the public beta build (2.2.0.651) should also fix this, as there is some better handling of the affected data.
As for removing the drive, is this an "Access denied" or a "File in use" error?
Either way, have you tried running the "Force Damaged Disk" removal option?  This may skip the problem files, and let you remove the pool.
Create an account
Register a new account
Sign in
Sign In Now
