I started having an issue a few days ago and i'm not sure of the exact cause, but the crash is indicating that covefs.dll is causing my problem. I've noted twice now while read and writing at the same time to the disk, after some time, the system bluescreens and reboots. Here are some details
File Server is a virtual machine (esxi), its running Server 2012 R2 with all applicable updates.It was moved a few weeks ago from one host to another. This was when I began using drivepool (which I am overall very happy with). I am running the beta version 2.2.0.651. The normal version was giving me some issues. If the suggestion is downgrading to the stable version, that is acceptable, but I wanted to report this none the less.
Here are the details from the crash and windows dump file:
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000001e (0xffffffffc0000047, 0xfffff800dfb0d7dc, 0xffffe00011db6d70, 0x0000000000007183). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 010116-30359-01.
Microsoft ® Windows Debugger Version 10.0.10586.567 X86
Are there any other logs or details I can provide to assist with this issue? Its difficult to reproduce, but has occurred twice in the past 2 days to me.
Tweak3D
