XAlpha
Measuring Speed
"Measuring" is taking a very, very long time (days).  Is there a setting that would allow it to measure multiple drives at once or to increase the threads to get this done faster?  DP Pool is ~90 TB with 30-32 drives.
What version of StableBit DrivePool are you using? (Can be located in the UI, or in the "Uninstall Programs" section of the Control Panel).
And what OS are you using?
And could you upgrade to the public beta build? (2.2.0.651)
There is some better handling of measurement issues, and better logging when something does go wrong.
Could you enable file system logging, and remeasure the pool?
Any disk that takes a while, may be the cause here.
Also, are any of the drives unhealthy? Eg, SMART warnings, or have issues with a surface scan or file system check?
