GiuseppeChillemi Posted January 28, 2015 Share Posted January 28, 2015 Hi, despite having set the balancers to 98% or 36GB free I have encountered a DiskFull problem. I have set to start the balances "no more often than 12 hours" The first balancer is "Ordered File Placement". I have unchecked this option to immediately trigger balancing. Drive Pool should not be allowed to reach a "Drive Full" status... Regards, Giuseppe Chillemi Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted January 28, 2015 Share Posted January 28, 2015 Have you messed with the balancer settings (I mean like the settings for Ordered File Placement and the like) at all? If so, how have you set that up? Quote Link to comment Share on other sites More sharing options...
0 GiuseppeChillemi Posted January 29, 2015 Author Share Posted January 29, 2015 Hi, here are my settings: Prior: limit to 12 hour was selected Prior: Volume O was duplicated by mistake Error has occurred on Drive M: Regards, Giuseppe Chillemi Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted February 3, 2015 Share Posted February 3, 2015 Ah, okay. If you don't have enough space on the pooled drives, it can cause the "not enough free space" error. Additionally, moving the sliders around in the "Prevent Drive Overfill" acan cause the disks to get fuller, and more likely to cause this issue. Quote Link to comment Share on other sites More sharing options...
GiuseppeChillemi
Regards,
Giuseppe Chillemi
