  • Create Account
EX495 WHS v1 system disk crashed
  • Please log in to reply
43 replies to this topic
#1 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 11 September 2014 - 05:59 PM
I'm waiting on some new red drives to get here so that I can do a recovery.  I have a ton of data, movies, pictures, movies of the kids, etc and I don't have backups.  On some other forums, I've read where some folks have lost all their data trying to do a recovery in v1.  From reading this forum, I see several how to's using your stable bit app.  There's a whs 2011 64 bit on ebay for $150.  Since you can't buy it retail anymore, is that my best bet for a safe recovery ?  Are the new features of 2011 worth that much ?
I tried a recovery with a green drive (pre AF) that I took out of an old ehd and the process failed trying to write to the drive.  I've since learned that the green drive isn't a good choice for a system disk.  I use three green drives that I ran wdidle and the alignment tool on and they work fine.  I'm  going to move them to an enclosure and expand my network.  Any advice would be appreciated.
#2 Christopher (Drashna)
  • Administrators
  • 8,394 posts
  • LocationSan Diego, CA, USA
Posted 11 September 2014 - 07:55 PM
Well, first, be careful with the ebay route. I've heard of people selling TechNet/MSDN keys as OEM/retail. Make sure it includes a COA sticker with the disk.
As for recovery, if you still want to use WHSv1, then use this link:
http://forum.wegotse...-to-new-system/
However, if you do wish to migrate to StableBit DrivePool, the process is fairly easy.
http://wiki.covecube...vePool_Q5463715
The process is detailed, but rather simple. If you don't feel comfortable doing this, we can set up a remote support session, and I can do this for you.
As for features in WHS2011: Windows 8 support, it's based on Server 2008R2 (the server version of Windows 7) and runs much better. It also supports system backup.
Also, WHS2011 is still being supported by Microsoft, where WHSv1 ended mainstream support last year.
And yeah, Advanced Format drives are bad for system disks in about any setup.
Christopher Courtney
aka "Drashna"
This is my server
#3 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 12 September 2014 - 02:16 AM
Christopher, thank you for taking the time to respond.  If I go to whs 2011, do I lose the media smart interface ?  Is there a simple way to install ?
#4 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 12 September 2014 - 04:36 PM
Never mind on the 2011 install, I found a link.  I had file duplication on when the system disk crashed.  Should I go ahead and recover v1 with the pool drives installed, then after all the updating, etc, turn file duplication off, turn off the server, remove the drives and install 2011 with StableBit ?  I don't want StableBit to reduplicate files already duplicated.  Or is StableBit smart enough not to do that ?
#5 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 12 September 2014 - 10:41 PM
Depends on which parts you're referring to. But chances are.... yeah.
IIRC, there is a hack to get the lights working again, if you're interested.
StableBit DrivePool is definitely smart enough to handle that. Specifically, that's why the guide has you resetting DrivePool's settings. This is to force it to process the pool and check the duplication status of all the files on the pool.
So no, there is no need to reinstall/recover WHSv1 at all here. Well, unless you want all the MSS software as well.
aka "Drashna"
This is my server
#6 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 14 September 2014 - 12:17 AM
I went ahead and ran recovery on v1 with a new red drive.  Installation went smoothly, but it took a long time, almost 12 hrs to pop on the network with the assigned name.  The connector software didn't let me assign user accounts and whs console couldn't find the server, neither could rdt.  I recycled power and was finally able to rdt into the server, and it flashed a warning that drive extender wasn't running.  I checked the pool drives and they still have data on them.  I shut down the server and pulled them out.  I really wanted to see if there was a hardware issue other than the dead system drive before I spent money on upgrading the unit.  I'm decent at managing our home network, because I'm curious by nature, but I'm not a hardware guy.  I can rdt into the server one time, if I do it quickly after cycling the power.  After that the rdt cannot find the server.  It shows up on the router all the time as having an address on the network.  There's a system problem, but how can I determine if it's hardware or software.
#7 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 14 September 2014 - 12:26 AM
I'd like to upgrade the cpu and ram, then install whs2011 and be done with it for a while.  Probably reuse the current pool disks in a jbod setup for more storage.  I don't care about the mhs software, I'd put in plex or servio, stablebit and others.
#8 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 14 September 2014 - 03:05 AM
it is possible that the wizard is still running and trying to update the system. It does this automatically, and can take a WHILE to complete.
Also, if you're rebuilding Drive Extender (aka, did a server recovery), this can take a long while as well.
As for he issues, if you're able to Remote Desktop into it at all, check the event viewer. It may have details about why it's becoming inaccessible.
As for hardware, that can be hard to tell. If you're willing to spend money on it... get yourself a VGA cable for the system:
http://www.mediasmar....php?f=6&t=8066
Not only can you see what is going on, it makes troubleshooting a lot simpler. And if you do want to upgrade hardware, it's almost a necessity, to make sure the CPU and RAM are working right.
aka "Drashna"
This is my server
#9 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 14 September 2014 - 08:10 PM
Thanks for the cable link !  That looks incredibly useful.  I think I'm going to do a restore with just the system disk in before I spend more money on it.  I appreciate the help.
#10 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 15 September 2014 - 05:01 AM
As somebody that owned both the EX470 and EX495, yes, that cable is INCREDIBLY useful. :)
Makes installing WHS2011 a lot simpler. :)
And you are very welcome.
Though, if I can make a suggestion: buy and install StableBit Scanner. There is a WHSv1 version, and it works mostly the same as the newer versions. Also, the license is compatible with the newer versions, so if you upgrade to WHS2011, you can continue to use the license on that system as well.
And since StableBit Scanner monitors the SMART data on the system and does a  surface scan of the drives, it's definitely a worthwhile investment.
aka "Drashna"
This is my server
#11 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 15 September 2014 - 05:35 PM
That's great advice.  I didn't realize there was v1 version of StableBit.  So if I do a restore, then disable DE which I'll guess is running as a service, add in StableBit.  At this point I could add my drives back like you've documented and not worry about DE formatting them ?  That sounds good.  Thanks again !
#12 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 15 September 2014 - 06:29 PM
NO, to clarify, only StableBit Scanner is available for WHSv1.
StableBit DrivePool is only for WHS2011, or Windows Vista and up. There is no WHSv1 version of StableBit DrivePool.
aka "Drashna"
This is my server
#13 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 16 September 2014 - 12:05 AM
Got it, trying to find the software at a decent price, hardware on order.
#14 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 16 September 2014 - 04:38 PM
Well, good luck. Amazon has copies, but they jump from ~$100 to .... much higher than that.
aka "Drashna"
This is my server
#15 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 18 September 2014 - 05:35 PM
Got everything on order.  Ran a restore with the data drives pulled.  Everything went well until the updates hung at 52% and stopped progressing.  I don't have time to mess with it everyday, so I think I'll quit torturing myself until I can install the cable.  My guess is that the server didn't reboot at some point during the updates.  It obtains an IP and sometimes shows up as hpstorage and sometimes as the name I gave it.  I can't remote into it, or connect to it.
The windows 7 computer I used for the set up saves the ip in a system32 host file.  Don't know why it would do that since the ip could change.  I had to change the ip in the file, then reserve it on the router.  The host file had saved the ip from when I tried to run a recovery at the beginning of the thread. Uninstalling the whs connector software doesn't clean the host file.  I guess XP didn't write to that file, oh well.  Wasn't the server's fault.  Fun little exercise learning how to enable a real administrator account.  Until I did all that, I couldn't initiate the connector software.
Good news is that it seems like the hardware is ok.
Is it worth the effort to install v1 with the HP software, then install 2011 ?  Or just run with the 2011 install ?
#16 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 18 September 2014 - 09:37 PM
Well, I'm glad that the hardware seems to be fine!
As for WHS2011... there is no upgrade path. It's a clean installation, period. In fact, the installer wipes the system disk, completely. So you'd want to remove any important data on the system disk before installing it.
As for the connector, as far as I'm aware, it's not supposed to write to the host file (but it has been a long while, so I may be mistaken).
aka "Drashna"
This is my server
#17 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 19 September 2014 - 02:28 AM
I'll post a followup after I get all the hardware installed, 2011 installed and of course your StableBit products.  Thank you for all your help.  I know you're busy with all the forums you moderate.  It may be next weekend before I can get all of that done.  Is there a native drive service in 2011 that I need to disable when running StableBit drive pool ?  Should I wipe the system drive before installing 2011 ?  Can't wait to get Serviio running again.
#18 Umfriend
Umfriend
    Advanced Member
  • Members
  • PipPipPip
  • 381 posts
Posted 19 September 2014 - 05:36 AM
No service needs to be disabled to run DP, it'll run clean out of the box.
I am pretty sure WHS will wipe the drive it will be installed on and entirely, not just the first partition if there are more etc. It claims one HDD in full.
Serviio runs like a charm for me even with a dashboard integrated interface that, although not maintenanced, still works with the most recent version of serviio.
#19 DaveO
DaveO
    Member
  • Members
  • PipPip
  • 25 posts
Posted 19 September 2014 - 09:40 PM
Thanks Um, all I'm waiting for is the cable to get started.  I come home from work today, turn on my computer only to get a notification from my tray that my computer's antivirus software isn't running.........damn thing must've updated itself into existence !  I can remote into it now !  Something to play with tonight after my daughter's softball practice.  It's also nice enough to tell me that I don't have an account set up......software didn't get that far.
#20 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 19 September 2014 - 11:45 PM
Umfriend is completely right here.
The big thing is that StableBit DrivePool was created to fill the void for pooling technology that was created when Drive Extender was pulled from WHS2011. So there is nothing to disable.
And yes, be careful when installing. WHS2011 will repartition and format a disk and take complete use of it during installation.
This means that you should clear the contents of one of these drives (the one you want to install to), and then disconnect the rest (just in case). Once you've installed WHS2011, it will use a 60GB partition, and leave the rest for "data".
To "clear" the data, move the contents of "D:\DE\" to another disk (the "D:\" drive from the server), assuming there is anything on it still.
Though, I'm glad to hear that it seems to finally finish updating.... and started working. :)
Though, since it's working, you may want to check out the following link to get Drive Extender to automatically evacuate the system disk:
http://forum.wegotse...-off-of-a-disk/
aka "Drashna"
This is my server
