  • Announcements
    • Christopher (Drashna)
      Getting Help   11/07/17
thepregnantgod
Migrate from Drive Bender to Drive Pool?
When both products were in beta, I picked Drive Bender and have been using it since.  However, recently, I'm getting a lot of dropped drives which is greatly frustrating.  The idea of running Stablebit Scanner along side Drive Pool has me considering the switch.
However, I have 20 drives totaling 60TB in storage with everything duplicated (a hidden duplicate on various drives) so manually recombining stuff is going to be a pain.
That being said, can someone familiar with both programs answer these questions for me:
1. If a drive drops, is there a manual/automatic tool that will identify which primary files were located on the dropped drive and then find the duplicates remaining in the pool and mark them primary then duplicate them?
2. Is there a caching mechanism?  What type of read/write should I expect if a file is being copied twice in parallel? All my drives are green 5400rpm drives yet on tests, I'm still getting around 60megs read/100megs write in my current config.
3. If Stablebit scanner finds errors on a drive - what does it do?  Some of my reading says it pulls the drive automatically - but then would it initiate (the answer the question 1?)
4. In the same vein, is there a tool to check the integrity of the duplication?  Can I scan for every file in a duplicated directory to confirm that it has a duplicate somewhere else in the pool?
Thanks.
Edit:
Larsp has posted an "unofficial" guide on how to migrate the Drive Bender pool to StableBit DrivePool, include a script to handle reorganizing the duplication into a format that StableBit DrivePool will properly handle.
http://community.covecube.com/index.php?/topic/511-migrate-from-drive-bender-to-drive-pool/?p=4554
-Christopher, aka Drashna
adding migration guide
13 answers to this question
I have just migrated from DriveBender and back to DrivePool. I tried DriveBender for a period, but it was just slower than DrivePool. When copying many files to DriveBender (ie starting FileHistory from Windows 8), it just stopped working and I had to restart the server. TV-recordings stored in DriveBender was also very slow and uresponsive in VMC. I never had that kind of problems with DrivePool. I do think that the interface in DriveBender is a little more "fancy" but stability is just more important.
Anyway. To migrate back to DrivePool i did the following (on a window server 2012 essential):
1. Installed DrivePool alongside DriveBender.
2. Release your DriveBender license before uninstalling
3. Set up a duplicate DrivePool on the same disks that DriveBender used.
4. Stopped DriveBender and DrivePool services from services.msc
5. Moved alle folders on physical disks from DriveBender root folder to DrivePool root folder.
6. Used the script below to move the duplicate files from DriveBenders location til DrivePools location (DriveBender stores the duplicate in a subfolder named FOLDER.DUPLICATE.$DRIVEBENDER, so you will have to move all the content in that folder to the folder below).
7. Started DrivePool and uninstalled DriveBender.
8. Used computer management to give DrivePool the same disksletter that DriveBender had.
Bat file to move files stored in FOLDER.DUPLICATE.$DRIVEBENDER to the directory below (hidden files will no longer be hidden as move doesn't move hidden files). This script has to be run on all the physical disks. Stand in the \poolpart.* folder. To try  it out, stand in a subfolder where you can't do much harm.
Please note that I give ABSOLUTELY NO GUARANTEE that the script will work for you. Try it out first, and if it seem to work, remove the echo
@echo off
for /r %%f in (FOLDER.DUPLICATE.$DRIVEBENDER) do if exist %%f (
  echo %%f
  cd "%%f"
echo  attrib -h *.*
  if exist *.* (
echo    move *.* ..
  cd ..
echo  rd "%%f"
All in all it took just 1 hour to set up and migrate from DriveBender to DrivePool and I did not have to duplicate 6 tb.
Welcome, and thank you for considering our products!
To answer your questions:
  1. We do not have a concept of primary or second files when it comes to duplication.
    At best, we will read from the faster disk, or from both, depending
    This means that recovery from a lost drive is trivial at best. The existing files are checked for their duplication status, and then copied to another drive, as needed
    http://stablebit.com/Support/DrivePool/2.X/Manual?Section=File%20Protection
  2. Yes, "read Striping", and as I mentioned, it will read from the faster drive if one of the drives is slower, or it will cache the files to memory and read it from there. More details about it can be found here:
    http://stablebit.com/Support/DrivePool/2.X/Manual?Section=Performance%20Options
    There is an "Archive Optimizer" balancer plugin that you can install. This balancer allows you to create a "feeder disk" or "landing zone disk", which files are written to and then later moved off of. Add a RAID0 array (or two) or a couple of SSDs, and you'll get much better writes.
  3. If Scanner finds damaged sections on the disk (as in bad sectors), by default it will start "evacuating" the drive. You can change this behavior, if wished (such as move out only unduplicated data).
    Additionally, you can (optionally) configured DrivePool to evacuate the drive on SMART errors. And you can set DrivePool to avoid placing new files on drives that have exceeded their rated temperature limit. (as these drives are statistically more likely to fail).
  4. DrivePool does this automatically, and daily. If it detects issues, it will let you know. Or if it's missing a duplicate, it will automatically copy it to another disk. And here is the link again:
I think I've answered everything and adequately. If not, then please ask away. Or if you have any more questions.
As for migrating... somebody else asked this recently. And the best answer I have (and this isn't a good one) is to disable duplication on Drive Bender, completely. And then migrate the pool.
Thanks.  I'm migrating now and though it's tedious with 60TB of data, I enjoy your product.  The interface is much cleaner and simpler.  I do have some questions regarding standy on disks, but I posted that question to a more relevant thread.
Yeah, I can definitely understand that.
However, for migrating... for the most part, it will be this:
  • (optional) unduplicate your pool in Drive Bender (I don't like this, but .... it's the simpliest method)
  • uninstall Drive Bender
  • Install DrivePool
  • Add each disk to a Pool in drivePool
  • Enable "Show Hidden Files"
  • Stop the StableBit DrivePool Service (in Services.msc)
  • Open each disk. There should be a {GUID}, and a "PoolPart.GUID" folder on each disk.
    Move the contents of the GUID folder (Drive Bender's pool) into the PoolPart.GUID folder
  • Repeat this for each disk.
  • Reset DrivePool's settings:
    http://wiki.covecube.com/StableBit_DrivePool_Q2299585B
  • Start the StableBit DrivePool Service back up
  • Change duplication status to what you wish.
As you do this, you should notice more and more files appear in the pool.
Additionally, you should notice a "duplication" sub-folder in each folder that DriveBender had duplicated. You'll need to either delete these folders, or move the contents into their parent folders.
The reason for this is that Drive Bender has a clear definition of "original" and "duplicate" files that it maintains. StableBit DrivePool does not. Each disk is identical in structure and folder layout.
So you can understand why I said "just disable duplication first". You may have to go through HUNDREDS of folders to fix this. Or write a script to do so. But I'm not comfortable with scripts that mass delete or move files like this, bad thinks can happen.
A word of caution, I too have a large pool, 27 drives, and recently moved from Drive Bender to DrivePool. The final result was not great, it seems that DrivePool does not handle large pools as well as Drive Bender, for me performance was very much reduced. I'm now in the process of working out if I should go from one large pool to a number of smaller pools, or switch back to Drive Bender.
@alkelly,
I'm sorry to hear about the performance hit. That shouldn't be happening.
If you could open a ticket at http://stablebit.com/Contact, I'd love to get this issue resolved for you.
If you're using Read Caching, try disabling that temporarily, and see if that helps.
Also, is Network IO Boost enabled?
And could you do this:
DrivePool v1: http://wiki.covecube.com/StableBit_DrivePool_Log_Collection
DrivePool v2: http://wiki.covecube.com/StableBit_DrivePool_2.x_Log_Collection
Let that run that way for about an hour, and then upload it.
I've just performed the migration, however I have to agree with alkelly, my pool is much slower under DrivePool. I have 22 drives, and there is clearly a performance difference. I was concerned that I may have done something wrong, but all appears to be ok, just seems DrivePool does not handle a large pools as well as Drive Bender. Now need to workout what to do, argh, split into smaller pools, or back to Drive Bender??
There are some options you will want to check in DrivePool.  I think these are mentioned somewhere in this thread, but make sure the following are enabled and then try again:
Go to Pool Options > Performance and make sure Read Striping and Network I/O Boost are enabled.
I have 20 drives in my pool, and network transfer rates are near max gigabit speeds (112 MB/s); The max is 125 MB/s.
That is very unusual that it doesn't get good speed.
While I only have 12 drives in my pool, I do usually saturate my gigabit network (~100MB/s).
Read Striping can definitely help, but that should be enabled by default, and only works with duplicated data.
However, Network IO Boost may definitely help out with network performance, but it may use a bit more CPU and memory. And by a "bit" it depends on the hardware in usage.
If the performance issues continue, please open a ticket at "https://stablebit.com/Contact" so we can help you more directly.
There seems to be a very important piece of information missing here. I just purchased The 3 product package so I can move my 2012 R2 server from DriveBender to Drivepool (having read this thread).
On unistalling DriveBender I was pretty horrified to find that Drivepool doesn't recognise any of my disks.
DriveBender has been supporting ReFS fo so long is it unthinkable for Drivepool not to support ReFS right? Right?
Hmmm.....
I have had lots of problems with NTFS over the years so I'm going to have to switch back now. Money well wasted!
Hmmm.....
I'm very sorry to hear about that.
However, there is a technical reason for this.
In part, because we do use some of the file system features that are not universally available in ReFS (File IDs and Alternate Data Streams).
Specifically, we store some information on the pool as Alternate Data Streams (including the duplication status of a folder), which isn't supported in the Server 2012 version of ReFS.
Additionally, there is a performance hit for using ReFS over NTFS.
Regardless, please open a ticket at https://stablebit.com/Contactand we can see about issuing you a full refund of your purchase.
I did 2 drives with drive benders 'remove' drive.. a week later, changed the whole set in one go and am currently moving from the drivebender subdirectories on each drive into the drivepool in a propper file copy.
It will still take a week to do, but importing the full disks into drivebender had many file protection problems, and probably long name problems, the copying, so far, hasnt. i'm getting about 2 TB a day this way.
I am impressed how robust drivepool is, in my fidling with usb lines I've knocked drives off a few times and it put itself back in working shape very quickly.
win 7, 7 drives, 12 TB.
