chrisschauer Posted December 23, 2013 Share Posted December 23, 2013 Hi, I had to replace a smaller disk from my pool with a bigger one. What I have to do? Add the new one to the pool and remove the old smaller disk? Drivepool do then automatically the movement of the data from the small disk to the pool? Is it really so easy? best regards Christian Tardas-Zib 1 Quote Link to comment Share on other sites More sharing options...
0 dbailey75 Posted December 23, 2013 Share Posted December 23, 2013 yep, if you want to do a direct replacement of a smaller drive for a larger drive, and you have enough room in the pool, you can remove the smaller driver, DP removes the data from the smaller drive, and allocates to the other drives in the pool, when done, power down the server, replace with the larger drive, boot it back up , add the new drive to the pool, I would reboot here again, just me it may not be required. and once your backup again, you can rebalance, or depending on hiow you have it setup, drive pool will add data to the new drive based on your balancer settings. also, If you have enough sata ports, and HDD bays, you can certainly install the new drive first, and then remove the smaller drive second. Quote Link to comment Share on other sites More sharing options...
0 chrisschauer Posted December 24, 2013 Author Share Posted December 24, 2013 Thank you for the answer! I'll follow your steps to replace the disk. I had enough ports free, so I add first the new disk to get sure that there is enough free disk space! Quote Link to comment Share on other sites More sharing options...
chrisschauer
What I have to do?
best regards
Christian
