Mount without assigning drive letter
Chupa
Good evening. I have a small problem.
I installed CloudDrive on my pc and uploaded to Google Drive for almost 3TB after I decided to change my operating system to switch from a Windows 10 to a Windows Server 2016, i formatted and installed the new operating system I installed CloudDrive and connected my account but I can not mount the unit (C:; D: etc) I do not know if this is because I did not press "Detach" before formatting or if it is because it is a trial version.
I attach a screenshot to you
Thanks so much
Drive letter assignment is actually handled by Windows, and should be automatic.
However, in some cases, this can happen.
As viktor has mentioned, you can use Disk Management to manually assign a drive letter.
Though, in future versions (and the internal betas), will will have the option to do so, from the UI.
Thanks for the answers, but also from disk management I can not see the virtual disk, is not it important that it is a trial version?
You only see my two local disks
I tried to use the BETA version, but even that was not able to assign a letter to the disk.
Edited by Chupa
I solved. I write it here so other users who maybe will have my own problem will be facilitated.
The disc was "Offline".
go to the prompt and type "disk part".
type "disk list" to see the number associated with the hard disk.
type "select disk <disk number>".
and lastly type "online disk".
Once this is done, CloudDrive automatically recognizes the disk and assigns it a letter
The only negative note is that the disk is read-only, but the data is accessible
Thanks again
aaah, yeah, that would do it.
Specifically, Windows Server defaults to setting all new disks as "offline" by default.
if you want to disable this (for ease in the future), open up diskpart again. And run
san policy=onlineall
And for more information about this:
https://technet.microsoft.com/en-us/library/gg252636(v=ws.11).aspx
