  • Announcements
    • Christopher (Drashna)
      Login issues   11/07/17
      Getting Help   11/07/17
Ninia
can not connect to webdav
hello,
hope someone can help me. i try to connect CloudDrive to a webdav provider is 1und1 (Germany) path to the server: https://sd2dav.1und1.de/
i tried with trial version of clouddrive on a normal windows 8.1 pc with File Share connect, the path and my credentials, connects and works.
now i bought a key, and installed it at my server, where i want use it and i cant connect, i always get  Error  Network Name not found
if i do again at my win 8.1 pc it works.
System where i get the error is a HyperV 2016 VM with Server 2016 Datacenter.
hopefully anyone can help.
p.s.: it is not the firewall, tried with firewall completely off and got the same Error.
Thanks for every help.
6 answers to this question
maybe,
but that is not the point, i can connect to it at my windows 8.1 64 Bit Windows PC.
Why not with server 2016 ?
that is the point, see attached Picture.
But it is the point.  The file share provider is designed to handle SMB/Samba/CIFS shares (windows file shares), and not WebDAV as far as I'm aware.  It shouldn't work on either, unless there is some redirection/trickery going on (which is entirely possible).  Or I'm missing something.
Either way, could you do this (on the system having the issue):
http://wiki.covecube.com/StableBit_CloudDrive_Web_Logs
http://wiki.covecube.com/StableBit_Troubleshooter
ok,
did both, first with the Website, cant put the saz file here, how should i send it to you ?
i did download to the dropbox-link at the site.
and the second link too, i put your Name (Christopher (Drashna)) in the contact request link - row.
by the way again, the machine with the Problem is  a HyperV 2016 VM with Server2016 Datacenter running.
thanks for your help
by the way, i took a look at your server rack link in your profile, nice setup.
if you are interested, mine is the same switch as yours.
server processor amd FX 8300, 24 GB RAM, WD Gold (Datacenter HD) as SYSTEM and VM-Disk)
Dawicontrol DC 7515 Raid Controller 5 Ports, 3 of them are attached, 2 are spare.
Data Disks are different WD Reds at mainboard sata III connections
Backup Disks are different WD Reds too, at a Dawicontrol DC 310e PCIE Raid Controller
system is running for years at server 2012 Essentials, now i did upgrade from 8 GB to 24 GB RAM and HyperV Server 2016 with 4 VMs at the moment.
vm1 - surveillance server (security cams, PRTG Network surveillance from Paessler)
vm2 - Smart Home server and HA-Bridge between amazon alexa and Smart Home
vm3 - File Server, Plex Mediaserver
vm4 - Web Server  IIS, FTP Server
at the file server i use stablebit scanner and drivepool for many years, love it, had never problems and never data loss, and i had some damaged HDs over the years.
now i want to connect my webdrive (1TB) with the clouddrive just for testing, maybe add it to the pool or as web backup drive, or as data drive for the surveillance cams.
many ideas, if it works with clouddrive.
Okay, I've flagged the issue for Alex (the Developer) so he can take a look into the issue, and verify what's going on.
https://stablebit.com/Admin/IssueAnalysis/27609
As for the server rack, thanks!
Though, if you want, feel free to post in the mentioned thread.
And very nice setup!
Create an account
Register a new account
Sign in
Sign In Now
