  • Create Account
Do I need to include .covefs when used with snapraid?
drivepool snapraid
Best Answer Christopher (Drashna) , 22 August 2017 - 11:28 PM
Only if you're mounting the drive to a folder on the pool.  If it's the other way around then, it doesn't affect the pool.
And remember that this data is stored on 3 different disks.  You'd need to lose 3 for the data to be lost.  (this behavior is hardcoded and CANNOT be changed)
Go to the full post
  • Please log in to reply
3 replies to this topic
#1 xilex
xilex
  • Members
  • Pip
  • 6 posts
Posted 22 August 2017 - 01:43 AM
Hi all. I'm testing out a setup under Server 2016 utilizing Drivepool and SnapRAID. I am using mount points to folders. I did not change anything in the snapraid conf file for hidden files:
# Excludes hidden files and directories (uncomment to enable).
#nohidden
# Defines files and directories to exclude
# Remember that all the paths are relative at the mount points
# Format: "exclude FILE"
# Format: "exclude DIR\"
# Format: "exclude \PATH\FILE"
# Format: "exclude \PATH\DIR\"
exclude *.unrecoverable
exclude Thumbs.db
exclude \$RECYCLE.BIN
exclude \System Volume Information
exclude \Program Files\
exclude \Program Files (x86)\
exclude \Windows\
When running snapraid sync it outputs that it is ignoring the covefs folder - WARNING! Ignoring special 'system-directory' file 'C:/drives/array1disk2/PoolPart.23601e15-9e9c-49fa-91be-31b89e726079/.covefs'
Is it important to include this folder? I'm not sure why it is excluding it in the first place since nohidden is commented out. But my main question is if covefs should be included. Thanks.
#2 Christopher (Drashna)
  • Administrators
  • 8,196 posts
  • LocationSan Diego, CA, USA
Posted 22 August 2017 - 08:05 PM
that's fine.
The .covefs folder is set to x3 duplication, so it will reside on three disks, if there are at least that many.
As for important, only if you're using reparse points (symlink, junctions, etc).
If you're not, then it's fine to ignore.
Christopher Courtney
aka "Drashna"
This is my server
#3 xilex
xilex
  • Members
  • Pip
  • 6 posts
Posted 22 August 2017 - 08:55 PM
Thank you. Does mounting a drive to a folder count as using reparse points?
#4 Christopher (Drashna)
  • Administrators
  • 8,196 posts
Posted 22 August 2017 - 11:28 PM   Best Answer
aka "Drashna"
This is my server
Also tagged with one or more of these keywords: drivepool, snapraid
