Martixingwei Posted July 26, 2017 Share Posted July 26, 2017 I tried to copy the "CouldPart-xxx" folder from my ACD to GSuite, then refresh the drive list on CloudDrive client, but the moved drive shows up as "[Destroyed drive]." What is the proper way to do this? Antoineki 1 Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted July 27, 2017 Share Posted July 27, 2017 Well, "the hard way" is the only supported method. The data format can be (is) different between providers. That said, you can download the data from ACD, and convert it to a local disk. From there, you could mount it and then copy to your GSuite drive. Quote Link to comment Share on other sites More sharing options...
Martixingwei
