MvL Posted April 24, 2017 Share Posted April 24, 2017 Hi, I noticed that after a copy action there is a lot of drive activity. Does Drivepool some magic on the background? Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted April 24, 2017 Share Posted April 24, 2017 "yes". It does balancing, and duplication in the background. More than likely, it's balancing, or at least checking the balancing. Additionally, are you using the public beta build (2.2.0.651) or newer? If so, and you're not using BitLocker, then you may want to do this: http://wiki.covecube.com/StableBit_DrivePool_2.x_Advanced_Settings Set "BitLocker_PoolPartUnlockDetect" to "False", and reboot the system. Quote Link to comment Share on other sites More sharing options...
MvL
