I'm running Windows Home Server 2011 and had a drive go bad. I didn't have any type of monitor plug-in, so I wasn't aware of it ahead of time. Not knowing what was wrong, I rebooted the server and it hung up on accessing the bad drive. I shut down the server, pulled the drive and brought the server back up. I replaced the drive and now when it's running a client backup, the drive I replaced will go missing and I have to reboot for it to be found in the pool again. I've removed the drive when there was no problem detected to see if it could clean itself up. That doesn't seem to have helped. Also, the warning for the scheduled cleanup task keeps showing up.
Any help on debugging and fixing this problem would be much appreciated.
dreamland95
Running Drivepool 1.3.785 Add-in
Thanks.
9 answers to this question
